www.unionmaterial.com.Hi all!
As I told in my last post, I am going to introduce you the Unionmaterial Dr. Pulley HiTClutch product. I was looking for a suitable clutch to replace the stock one but I realised that almost of all the clutches available in auxiliary industries are exclusively centrifugal force actuated.
I only found one that supposes a new clutch operation concept for automatic transmissions. This is the Dr. Pulley HiT Clutch. The main characteristic that does different of other clutches is that is NOT exclusively centrifugal force actuated. The other source of actuating is the maximum torque from engine.
I will try to explain you. Firstly the clutch actuates like an traditional one, the weights are separated deforming the springs by the centrifugal force and then (in maximum torque level of rpm) a new set of springs are deformed turning a plate containing four pins that pull the weights stronger against bell.
It is very simple mechanism and the manufacturer promises a very important gain of effective power to wheel, hillclimbing and performances.
On my own opinion, I think the manufacturer has developed a revolutionary product that accomplishes the needs of high-powered engines clutches.
I held contact with Paul Wu, he is an efficient and easy-going professional and he has answered me so fast when I ask for something.
I attach two documents in which you can see more details. The first one is the user handbook that shows the principle of operation clearly and is available in the web www.unionmaterial.com. The second one is the users feedback and was sent me by Paul.
I invited him to participate in our forum to give more information about his products, prices and sending costs.
Thanks for your attention.
Best Regards,
Asunto: Embrague Dr. Pulley
Asunto: Re: Embrague Dr. Pulley
http://www.youtube.com/watch?v=XR_p1H1Hrro
http://www.youtube.com/watch?v=hKfCcOoD3-I
Hi,
If you're going to visit 2010 Eicma in Milano,you can go to booth no. # O70-4, Pav. 4 to see the tuning parts from Dr.Pulley
Hi,
hi friend.
Where can i buy this product? wich price with shipping?
greetings
RAYJASPER Escribió: [Ver Mensaje]http://www.youtube.com/watch?v=XR_p1H1Hrro
Hi,
hi friend.
greetings
Hi,
You can contact www.turbokit.net to see if they have the parts in stock if there's no stock then you can order it from Dr.Pulley in Taiwan through
Email
La verdad que pasada esperamos noticias tuyas para saber si es efectivo, gracias por tu esfuerzo.
+1, esperamos la cronica y sensaciones de tu experiencia con ese embrague.
Javierillo Escribió: [Ver Mensaje]
Muy bien documentado... interesa un monton saber mas en la practica. Muchas gracias.
Página Generada en: 0.2994s (PHP: 29% SQL: 71%)
